20 Most Recent Technics SA-AX530 Receiver Questions & Answers
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Technics... | Answered on Sep 04, 2017
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Technics... | Answered on May 25, 2015
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Technics... | Answered on Dec 17, 2013
R91 is a 1K Ohm
M1 is FSDM0356
Technics... | Answered on Mar 01, 2013
hello. we cant help if we dont know what music source you are using.
Technics... | Answered on Sep 01, 2012
Only connect audio...you do not have a video option available with this unit but the optimal connection is always audio only between TV-receiver.
Connect any RCA cable jack of your choice from the audio out connection on the TV it may be labeled as "variable audio out" or simply "audio out" into the audio left and right channels of the TV section of your receiver. Be sure the channel connections between the receiver and TV match up and power it all on, connecting is finished.
Technics... | Answered on Feb 22, 2012
That would depend entirely on your unidentified subwoofer and what IT needs. The Receiver puts out a usable Subwoofer feed on an RCA jack. That would suggest an RCA Cable, huh?
http://exaudio7.netserwer.pl/allegro/technics/sa-ax530_2/sa-ax530_7.jpg
Technics... | Answered on Sep 03, 2011
You need a cable (from Best Buy or Radio Shack) that is "Mini" jack (Ipod end) and dual RCA on receiver end.
Technics... | Answered on Apr 03, 2011
Hello,there is a chance that you have a damaged speaker and that the amp is ok. Check the unit with no speakers at all connected,if there is no overload displayed then its a bad speaker.
Technics... | Answered on Feb 10, 2011
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Technics... | Answered on Feb 09, 2011
This manual discusses it somewhat.
http://service.us.panasonic.com/OPERMANPDF/SAAX730.PDF
Basically, feed the self-powered (active) subwoofer from the Subwoofer Out. There does not seem to be a way to adjust the subwoofer output to match the rest of the speakers because the sub out is muted during the adjustment procedure.
Another way would be to refer to page 15. The note at the bottom right suggests your subwoofer might accept full range speaker level inputs. Refer to the manual for your sub. I believe they mis-printed it and meant "active" subwoofer, as simply wiring a passive (unpowered) sub across the front speaker outputs might cause some amplifier overload issues and you would have no way of balancing it anyway.
Technics... | Answered on Jan 17, 2011
check your speaker connections, or unplug all your speakers and verify the problem still happens. If so it is an internal problem and most likely not worth getting repaired.
Thank you,
Lee
Technics... | Answered on Aug 25, 2010
there are too types of fuses used today there are glass and thermit if its glass then simply remove the cover of the amp find the fuse and replace with new one if you look around and cant find a glass fuse then it has a thermit fuse and they are solded to the bord and really need to be replaced by a tech however if you can solder then email me and ill send you a diagram on what to look for and go from there
Technics... | Answered on Jun 25, 2010
Technics SA-AX530 Receiver Logo
43 questions posted
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Technics Audio Players & Recorders
Most Popular Question
replace fuse
  • Audio Players & Recorders
