Washing Machines Logo
B
Bob McCaughan Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I remove a GE top loader agitator? - GE Washing Machines
David Spradling
Level 3:
Top Expert:
  • GE Master 13,524 Answers
  • Posted on Nov 16, 2020
David Spradling
GE Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929716
Points
28396
Remove fabric softner top then remove screw at bottom and wiggle agitator off
Top Loader GE with impeller not agitator leaving oily looking stains
Remove the bottom impeller and clean out the water proof grease that has come out of the seal and drive shaft.
2helpful
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Pants tie stuck around agitator on older model top loader. How do I remove the agitator?
If it is newer you yank the agitator off there by grabbing the neck
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Agitator removal to remove clothes stuck beneath
for the basic top loader there should be a cap on the top of the agitator you can pop off with a flat screw driver and then use a ratchet with an extension to get to the nut holding the agitator on, 1\2 inch or 9\16 socket, i think.
2helpful
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
GE TOP LOADER DOES NOT AGITATE DURING WASH CYCLE BUT DOES SPIN DURING EXTRACTION
Remove the agitator and check the agitator splines also the agitator coupling on the shaft may be stripped.
3helpful
2answers
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
