Health & Beauty Logo
R
Roberta Cannon Posted on Sep 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing battery on scale #5786 - Health & Beauty
David Gust
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Sep 24, 2019
David Gust
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
70167
Points
779
Without the brand it is impossible to answer. But try using Bing to search for the brand and model and you may find the answer to your question.
I replaced the batteries of my Omron Karada Scale BF511 and it's been showing Err. When I step on it, the scale reads up to a 110kg (and I weigh 76kg) before reading Error. Please help.
Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. Make sure the scale is on a flat, stable surface: Uneven or unstable surfaces can affect the accuracy of the readings. Place the scale on a hard, level floor and ensure it is not wobbling.
2. Check the battery installation: Double-check that the new batteries are inserted correctly, following the polarity markings inside the battery compartment. Ensure there is good contact between the batteries and the terminals.
3. Calibrate the scale: Some digital scales require calibration after battery replacement or when experiencing issues. Check the user manual for instructions on how to calibrate your specific model. Calibration usually involves placing a known weight on the scale and adjusting it accordingly.
4. Clean the scale: Dirt, dust, or debris on the scale's surface or sensors can interfere with accurate readings. Use a soft, slightly damp cloth to clean the scale, ensuring it is dry before use.
5. Try weighing yourself multiple times: Step on and off the scale a few times to see if the error persists. This can help determine if the issue is consistent or intermittent.
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
3helpful
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
4helpful
3answers
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
18helpful
3answers
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
5helpful
When you step on the scale the readout says "LO". Does this mean low battery, and if so I can't find a battery to replace.
Yes it means battery needs replacing. Check oringinal papers that came with scale to see if you need to order special battery. Otherwise go to a battery store that recharges batterys. They usually carry most makes. Take your battery with you so you can match right one.
1helpful
Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Battery
HI ,copy and paste this link into your address bar ,it will take you directly to the company that has your laptop battery. http://www.lowcostbatteries.com/Laptop-Batteries/Everex/StepNote_MX_n/11_mid_234_modno_19093.htm
THE part number is B-5786 at $124.95
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
