Charger lights do't change and talkies never power up full. Thanks in advance
Youmay need to have the batteries repacked or replaced I would think as a first guess
Hi Anonymous, as you say, your batteries have little or almost no charge capacity
That's why the charger lights remain on
Simply replace the batteries.
I hope you can solve the problem
Greetings Franco Dosil
Hola Anonimo, por lo que comentas, tus baterias tienen poca o casi nula, capacidad de carga
Espor eso las luces del cargador permanecen prendidas
Simplemente, reemplaza las pilas
Espero puedas resolver el problema
Saludos Franco Dosil
https://fccid.io/BBOLI4900/User-Manual/USERS-MANUAL-751014
Testimonial: "Thank-you Franco for your prompt answer. Will order new batteries. Thanks, Charles"
SOURCE: Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
SOURCE: motorola talkabout t5700
No, the charger is only usable to charge the rechargeable NiMH or Li-Ion battery which comes with the radio. Attempting to charge Alkaline rechargeable batteries with this charger could cause the to expode. If your charger is not charging the batteries which came with the units, it could be you do not have the charger cord end plugged in all the way, or the batteries dropped below the initial charge level by setting on a store shelf too long. Most TalkAbouts come with a cradle style charger to hold the radio, and a possible plug to plug into the charge hole. Check all connections, and clean any battery/charger contacts with a pencil eraser. To re-initialize the batteries you would need to attempt 3-5 charge cycles by charging for 8-10 hours, then letting the battery rest for 8-10 hours, repeating 3-5 times as needed. If this does not bring the battery back to life, you need to replace the batteries.
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
SOURCE: I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
SOURCE: Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
