SOURCE: Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
SOURCE: Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
SOURCE: Roper Washer filled with water and then stopped
HI thanks for your question. the problem you are having is with the lid switch, which is located uder the top. replace the lid switch. if you need further assistance . plese get back to me thanks the appliance doc. please rate my answer thanks
SOURCE: Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
