Change the air filter, that’s almost always the problem. You could also change the fuel filter and spark plug. It wouldn’t hurt. Although it could be the carb, These things I mentioned should be tried first.
Try cleaning the carburetor and blow or clean jets. Then new mix and clean fuel. Start up, and probably set the idling to a little faster to start then adjust for good idle speed so it won't stall. Hope this may help.
SOURCE: Homelite 16'' chain saw runs rough and backfires
One of two things is wrong. This saw is so old I doubt it has electronic ignition. Pull the flywheel off and clean the points with carb cleaner and sand the contacts very, very lightly with super fine sandpaper or a little file. Second option, the coil is bad, take it to the shop and they should be able to test it for you.
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
SOURCE: my homelite super 2 chainsaw keeps flooding. it
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to homelite.com to find manual for the saw.
SOURCE: old homelite XL chainsaw pumping bar oil into engine while runnin
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
