The Normal, Heavy and Smart lights will blink when there is low water level in the dishwasher. Check that the sump area isn't blocked from filling with water. Often there is a float inside the tub that can be held down by a utensil that fell under the lower basket. Remove any foreign objects. Then try to run the dishwasher when it is completely empty. The parts diagram for the dishwasher is available here: https://www.searspartsdirect.com/model/60yajq87a8-001482/samsung-dw7933lrabb-aa-01-dishwasher-parts . If there isn't an obvious blockage in the water level monitors, you could have a wiring problem or an issue with the control board that doesn't get the signal for water reaching the desired level. (Note: if the incoming water pressure were too low, only the Smart light would flash.)
The manual for the DW7933LRABB is available from Sears Parts Direct on the product page: https://www.searspartsdirect.com/manual/60yajq87a8-001482/samsung-dw7933lrabb-aa-01-dishwasher . The current link to the manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1206228L.pdf .
I hope this helps.
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
SOURCE: Normal cycle light flashing
If its the ormal led flashing that is normally caused by a stuck key ing the key pad. Might try unplugging and plugging back in but sounds like you need a new touchpad.
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
