Toshiba Satellite A135-S2386 Notebook Logo
Posted on Sep 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to fix out about getting a 15' Toshiba satellite laptop screen fixed. It has a creak on the left side in the corner
Anonymous
Level 3:
  • Master 1,555 Answers
  • Posted on Sep 08, 2009
Anonymous
Master
Level 3:
Answers
1555
Questions
0
Helped
438975
Points
4726
Sorry on our part we can't extend our hands for that sort of fixing cause it requires your personal attention and intiative. There's nothing which an expert could do in fixing a cracked or broken lcd/tft screen. unless he is physically handling the unit. In my view its best suggest kindly check the amount for screen replacement and the amount for latest laptop. Whichever is ok for you, you can go for it. Or kindly just let me know with your country and state I'll try the best for you.
  • 1 more comment
  • kenedy
    kenedy Jan 08, 2014
    India, State Manipur (Imphal)
  • kenedy
    kenedy Jan 08, 2014
    i need to do in your suggestion, give me good suggestion
  • kenedy
    kenedy Jan 08, 2014
    but my pc is not Toshiba, it is hp i3 M370 @2.40ghz 3gb Ram 500gb Harddisk
Anonymous
Level 2:
Sniper:
  • Expert 58 Answers
Anonymous
Expert
Level 2:
Sniper:
Answers
58
Questions
0
Helped
24400
Points
237
Need to contact Toshiba tech shop in your area to get it replaced
Contact 800-316-0920 or
Locate a Service Center :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
2answers
Hello my toshiba satellite c650 lap top turns on and then the screen goes black with a - on the top left hand corner and cant do anything so i wait and nothing happens how do i fix it
I cant help you resolve your problem but i have the same problem with my Toshiba but when the screen goes black i get a high pitched buzzing and i cant do anything but turn it off. I was replying because if you got a solution to why yours was doing this would be great if you could help me out..Thanks Tanya x
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Need LCD screen for Toshiba Satellite A15-S127 15
You can try getting it here: http://lcdscreen.com/ but you should open it up and get the model number and maker of the LCD panel to make sure you are ordering the right one
My toshiba has balck screen with flashing courser top left corner
Reboot, and hold F8 to enter safemode, from there you can try to use a quick restore to go back to an earlier time of the week or month to see if that fixes your issue. you can also run virus or malware scans from safemode.
2answers
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
2helpful
4answers
Toshiba Satellite A135 is DEAD!
Open the back panels, blow out EVERYTHING and remove and re-insert everything. You could just have dirty contacts somewhere. The dust from the fans also travels around inside the computer.
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
