Hi, i am getting a Runtime Error! Program: C:Program files he print shop 22pmw.exe This application has requested the runtime to terminate it in an unusual way." When I press ok the whole program closes. What does this mean and how do I fix it?
Go to www.google.com and in the search box type "download google chrome" (without the quotes). Download and install a fresh copy of Google Chrome from Google Chrome's website without losing any of your bookmarks.
Hi,If you want to fix the problem you can try to reinstall the application.
If you just want to disable the message you can try this:
1. Go to Start Up \ Run command and type: msconfig then press Enter.
2. Go to Windows StartUp and search the item with this string: "C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe" and remove the check. Then Apply and Close.
What version OS are you running?
Have you tried updating?
Try this link
https://www.howtogeek.com/forum/topic/this-application-has-requested-the-runtime-to-terminate-it-in-an-unusual-way
Does the Program issue you the name of the suspect runtime library at any point? If it does, go get the latest version of the runtime from the NET, in a searchengine type the name of the file+ext. download and then copy it in the same direrctory (folder) as the one on your system now.
NOTE: I would FIRST rename the one on your system as <currentfilename.current_extention>and then add .OLD to it.
