AT&T High Speed DSL Modem Logo
Posted on Sep 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Describe your AT&T High Speed DSL
Describe your AT&T High Speed DSL Modem Problem I keep getting a message to enter my passcode.
Anonymous
Level 2:
  • Expert 136 Answers
  • Posted on Jan 29, 2010
Anonymous
Expert
Level 2:
Answers
136
Questions
Helped
74424
Points
349
The passcode is the four digit code that you had created while registering the account
Try to remember that code and enter it
If no choice call AT&T tech support
1helpful
The dsl and internet lights on the modem are red. Message on the computer keeps saying broadlink is currently not available.
In that case, you will need to reset the modem that you have, at the back of the modem, there is a pin hole that you need to push, I believe you will need a pen or a pin to press that button. Press and hold the button while the modem is on for at least 30 seconds then turn it off, after 30 seconds,turn it back on and if its still the same, you will need to replaced the modem.
Hope this will help...Your response is very much appreciated...
1helpful
My dsl light keeps blinking and I can't get on the internet because it won't stop blinking
  1. Step 1 Ensure that your AT&Tmag-glass_10x10.gifDSL self-installation kit is complete. At minimum, it should contain aDSL modem, an AC adapter, an Ethernet cable, a telephone cable, severaltelephone filters and an installation CD.
  2. Step 2 Installthe telephone filters on each telephone jack that you have a phoneplugged into. Install a dual phone adapter on the jack closest to yourcomputer if you have an answering or fax machine, telephone or analogmodem in the same room. Then plug your telephone equipment into thefilters. Connect the telephone cable that was provided with yourinstallation kit into an unfiltered telephone jack.
  3. Step 3 Insertthe installation CD into your CD-ROM drive. If the installation programdoes not start automatically, click Start > Run > and browse tothe CD-ROM drive directory to find the installation file.
  4. Step 4 Connectthe telephone cable that is attached to the unfiltered wall jack to theback of the DSL modem. Connect the Ethernet cable to the back of themodem and to the Ethernet network interface card port on the back ofyour computer. Connect the AC adapter to the back of the modem and plugit into an electrical outlet. Power the modem on.
  5. Step 5 Checkthe modem lights. There should be at least two lights lit. These willhave labels such as "Power" and "Ethernet." However, these labels maydiffer depending on the model of modem you received in yourinstallation kit.
  6. Step 6 Completethe software installation. Enter your chosen username and password whenprompted. Check your modem to see if the light labeled "DSL" or"Internet" is lit. Open a web browser window to see if your DSL servicehas been successfully installed.
1helpful
Getting a solid red power light on modem and losing the DSL/internet connection, brand new modem whats up?
Bought a new modem Zoom model 5654 X5 We are smoking on the internet at high speed now.Returning other one to AT & T for credit it was defective.
2helpful
Change password
If you are looking to change the system password
go to the router page go to system and go to system password and change the password
if you dont know to access the router page
Open a browser and enter 192.168.1.254 and hit enter
Enter the username and password to access the router settings page
This should work for 2701hg-b Modem/Router
If 1701 or 1800 use 192.168.1.254 or try 172.16.0.1
When trying to use DSL, lights all on, get message
You need to call your ISP. They can reset passwords and user names. I work with an ISP and it happens all the time. System erase things and you will need them to help. Hope your the acct user cause we guard info heavily.
>> do i have to call my internet service provider to activate my modem?
Yes.
Each modem has a unique "address", and your I.S.P. uses that address to authorize each DSL-modem that tries to connect to their network.
Or, if the two of you live in the same house/apartment, you should just buy a "router". Then, both computers can connect to the router, and the router connects to the DSL modem, and both of you can "share" the monthly fee for the _one_ Internet connection.
2helpful
2answers
I have an AT&T Modem; having trouble with internet connectivity
It is OK to keep putting the UN and PW in. However you shouldn't have to. I suggest having a tech come to your home and have them do a signal test both at your jack and outside with your home unplugged from your service box. If there is a big difference in the numbers then you're simply loosing signal due to signal bleed inside. This is a simple fix. Have them isolate some wires in your jack and place a DSL filter outside. Then your DSL signal will go straight to your modem and not bounce all over your home. This will NOT affect your phone.
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Top AT&T Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
