Toro electric blower/vac Model 51591 will not turn on. There appears to be a circuit breaker that will not stay depressed. The circuit breaker has two blue and two red wires. When the breaker is depressed and held, each blue wire connects to one red wire. 1) Is the breaker broken? Where can I purchase a replacement? Can I bypass the breaker - I'll plug into a GFI?
SOURCE: sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
SOURCE: how do replace the impeller on a toro 51591 super
Toro and Sears blowers are pretty much the same. It is not worth the trouble to replace. Good Luck
Still will not turn on. However, the apparent circuit breaker behaves like a safety interlock switch, so that is probably not the problem. The speed switch diode is 40K in one direction and open in the other - probably OK. What else could it be?
