Theres a multitude of areas you could look at. Being that it is a Parallel-ATA Drive, I'd start by making sure your BIOS is supporting/set correctly. Second, have you Already installed an OS? for that matter, is it a new or used HDD? Has it booted for you before? (on your system), the HITACHI drives are usually pretty good. More info would be helpful if you can.
Cheers.
How many hard drives have u got in the machine have u set this drive as the boot ?
The comp detecting the HDD is irrevelant, the fact it detects it means only it has detected the electronic part of the drive, if the actual mechanical part of the drive, and the platter are failing, then it will not work, i suggest taking it to someone who can test it.. you will know then
Thanks,
I have installed the operating system, while installing operating system it creates the partition, but after some period it automatically deletes all the partition, and gives message that Boot Disk failure.
Thanks,
I am trying to install operating system, first time it created the partition on HDD but after restarting it is deleting the partition. Means i am not able to see any partition and it gives message that BOOT DISK FAILURE
wrong partition table detected cannot format how to write it to zero or low level format ata modelHDS728080PLAT20
after booting with the windows xp2 cd the disk is copying the new files but it is not getting installed after restart. what can i do for this problem
HDS728080PLAT20
