20 Most Recent
Gateway 552GE PC Desktop Questions & Answers
Only the fans runs on start up.
If all you get is fans and maybe some lights on, then you most likely have a bad power supply. Buy from the store for $20+ and watch a youtube video on how to replace. I'd rate it at a 2/10 for difficulty. Very easy repair.
My dvd will not eject
Sounds like you need a new one. If theres a disk in there which you need you will see a very small hole on the front of it which is an emergency eject. I normally straighten out a paper clip and poke it in. A new DVD copier is only about $25 and very easy to install only 2 plugs which can only go in one way. If youre not confident doing it yourself its only about 10 mins work so any shop should not charge too much. Cheers and please vote
GETTING ERROR: REBOOT AND SELECT PROPER BOOT
its not detecting your HDD. on boot enter BIOS & check whether your HDD is being detected by the MB. IF not(most possible) then check the power & data cables to your HDD, Check your SMPS too, if SMPS OK then your HDD is corrupted. GET new HDD
Describe how to install memory into a Gateway
memory pops in and out of normally vertical dimms make sure power cord is not pluged in the press white clip out then make sure memmory lines up correct one short line and 1 long line of gold connectors match the gap to the tab press untill white tabs click in place
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
- Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
- Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
- Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
- Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
- Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM •
Gateway...
Answered
on Feb 26, 2023
