The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
Replacement of the
lamp should be carried out by a qualified appliance repair service.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
But here is a basic method if you are
mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its
position is adjacent to the vent holes that it shines through.
If
you feel confident, disconnect it from the mains power, remove
anything in the cavity.
Remove the microwave cover. Purchasing a
new replacement lamp will be useful as it will give you an idea of
what it looks like. Locate the dead lamp remove the lamp and fit the
new one. Replace the covers. Plug it back in and try the lamp by
opening the door.
Hope this helps.
