Sony Ericsson K800i Cellular Phone Logo
Posted on Sep 01, 2009
Mailbox full phone not connecting when dialed and message cannot be left because voicemail says `mailbox full ' and no reference to be found in manual.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
10443
Points
50
You have to dial 1 to get in your mail box. Follow prompts to listen to your messages. If you never activated your voicemail your password is most likely the last 4 digits of your cell phone number. Delete messages and your mail box will be able to take new voice mail. Worse case scenario, go to your nearest store and ask a representative to reset your password to clear the messages.
1helpful
Mailbox is full, how do I empty it please?
The "10B1" message on your Panasonic KX-TGD390C phone may indicate that your voicemail box is still full, even if you've deleted all the messages. This could be due to some saved or undeleted messages in a different folder or some other issue with your voicemail settings. To clear your mailbox and resolve this issue, you can try the following steps:
  1. Access your voicemail box: Dial your voicemail access number. It's typically a number provided by your phone service provider, such as "123" or "555."
  2. Follow the voice prompts: Once you're in your voicemail system, listen to the voice prompts carefully. There should be an option to manage your messages or change your mailbox settings.
  3. Delete all messages: Even if you've already deleted messages from your phone, there may be some messages still stored in your voicemail box. Use the voicemail system's options to delete all messages.
  4. Check saved messages: Some voicemail systems have a separate folder for saved messages. Make sure to check this folder and delete any saved messages if they exist.
  5. Change mailbox settings: If you cannot find any messages in your voicemail box and it's still showing as full, you may need to access your mailbox settings and reset or reconfigure them. Look for options related to mailbox size, message retention, or other similar settings. You might need to contact your service provider for assistance if you can't find these settings.
  6. Reboot your phone: After you've taken the above steps, it's a good idea to power cycle or reboot your Panasonic phone. This can sometimes help refresh its connection to the voicemail system.
  7. Contact your service provider: If you're still experiencing issues after trying these steps, it's a good idea to contact your phone service provider's customer support for assistance. They can help you troubleshoot and resolve any voicemail-related problems.
Remember that the specific steps and options may vary depending on your phone service provider and the voicemail system they use. It's essential to follow the prompts and options provided by your voicemail system when you access it through your voicemail access number.
My phone keeps saying mailbox full and callers cant leave a message.How do i solve this.I have no manual.
Your mail box is for voicemail and it would be a number that you call to listen to messages that are left for you. The company that provides your cell phone service would be able to tell you how to check your voicemail so that you can free up space.
3answers
How to reset the pass code to get messages
Nec Electra phone reset
1. Login into Voicemail
2. Go to admin Feature
3. Follow the instruction
After that your phone will be reset.
008ce543-db10-480d-b83b-2eba9c70077c.jpg Nec sv8100 IPK DTerm phones Inlinecom
How do I check messages left on voicemail from another phone?
Call voicemail, dial #6 followed by * and your mailbox number, then you will hear prompt for password if your mailbox is password protected.
3helpful
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
1helpful
Voicemail not working How to record a message
Depending on what type of voicemail you have installed this should be the way to setup your voicemail. Typically if you dial your voicemail extension and press * when the main greeting starts it will ask you for your mailbox number. Usually your mailbox number is the same as your extension number and you password is defaulted to your extension number plus 997. If your password doesnt work you will have to go into the administrator mailbox which is 999. the password is usually 999997. Go to option 8 on menu then option 4. this will reset your password on your mailbox to default. Also included a website with Toshiba manuals. Hope this helps.
http://www.wedophones.com/ToshibaManualsLead.htm
3helpful
2answers
Can't find how to set my voicemail message on Panasonic KX-T7431
Thanks for all the helpful information! First of all, I think you have a TVS/TVM voice mail system. That's good, but what does the lady say when you dial 265 or 165 from either your phone or a phone that works?
If you have voice mail set up, the prompt would be to "Enter your password then #" or "You have X new messages" if you don't have your password set. If you don't get ANY of those on your phone, but do on someone else's, you don't have a mailbox.
Mailboxes are added from the System Owner's mailbox (999) by
option 6 then 1. Once you have a mailbox, you do use option 5 and 3 or 2 or 1 for Name, Password, and Greeting.
Since there is little difference between the models of voice mail, I have attached a TVS-50 manual. The instructions for adding a mailbox start on page 280 (or use the System Manager's Guide tab on the left).
http://public.carl.airpost.net/TVS/TVS-IM.pdf
With any luck, you'll get voicemail too :-)
Carl
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
It's driving me crazy
Look in the manual about the voicemail indicator. It may need certain services not available in all areas. Ask your phone provider if that is the case.
Mainly, your phone has a voicemail. so dialing 1-800-VOICEMAIL is different that pressing the message play button locally on the machine. If you dial a phone number to check your messages, that is the problem. The messages are on your phone, and/or your voicemail service. If you have a dial in voice mailbox, disable the built in voicemail on the phone. email me [email protected] if you need a link to the online manual or any other help
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
