You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
Pull off the speaker grill. Remove the 4 or so screws along the bottom edge of the screen. The screen will do one of two things: Either it will lift about two inches and then it will pull straight off, or it will hinge out from the bottom about 8 - 10 inches and then it will lift off the hinge at the top.
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
OK
Take the screws out of the BACK top panal of tv! be gentle the mirror is connected to this back!.... now after removeing back you will see the inside of screen and the three lenses and on back panel the mirror! clean all three of these and you will see a big change for the better..Then just replace back! (The screen itself does not come out!)
Please take a second to place a rating for my answer!
thank you!
Remove speaker girll.No screws to remove grill just pull off.At the bottom of the screen frame you will see 4 1/4 inch screws.Remove screws and lift screen straight up.Clean cob webs and clean off lenses.I do not reccomend cleaning the mylar mirror.It is very delicate and you will scratch it.You can use windex to clean lenses.Good luck.
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
