Replace old battery with a new one or make sure yours is getting a good charge.
any drop in battery power will turn radio off.
I oversee about 80 units and this has happened several times and a new battery most times does the trick.
There will be an option in the phone that to wireless get turned off after some time. try to find that option and turn that off.
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop keyboard it should have a key something like (((.))) press it on
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required.
If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Locate the Wireless LAN switch located on the front of your Acer Notebook.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Connect."
or
Power on the Acer Aspire laptop.
Right-click the wireless Internet icon in the lower right corner of the desktop.
Select "Enable" from the pull-down menu.
Right-click the wireless icon again.
Select to view all available wireless networks in the area.
Momentarily a window appears with all of the available Wi-Fi networks.
Select the Wi-Fi network you want to connect to, then type in the password (if required).
Click "Connect," and your Acer Aspire computer connects to the Internet.
hope this helps
