GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
Anonymous Posted on Aug 26, 2009
Anyone solve the howling problem please share.
My GE GSH25JFTA cc howls, getting worse, along with the howling, the fan races up and down.
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Aug 26, 2009
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
992137
Points
5072
Sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Testimonial: "I appreciate the answer. I guess I would replace the fan?"
  • Scott Gilson
    Scott Gilson Oct 22, 2013
    FINALLY fixed this problem. It's NOT the fan motor. Tried that. It's NOT the control board. It's NOT how full you load the freezer or fridge. Mine is full. The problem is this: When they ship the units from the factory, there are two pieces of rubber trim that seal the left and right side of the fan box at the back of the freezer. During shipping, the trim slides down, exposing a 1" to 1/2" gap where air can get sucked in. This turns the fan box into a musical instrument. FIX: I simply put some electrical tape over the open spaces, and the howling stopped. It's been a week with no sound at all. Previously it howled all day, every day. The proper fix is to loosen the fan box and slide the trim back up into place, but putting tape over the gap will do the same thing and is easier. Enjoy your quiet kitchen! P.S. to GE: Please put some sealant on these gaskets before you ship them from the factory, so that they do not slide out of place during shipping. I'm sure they were silent when they left the factory, but you need to account for shipping. And inform your telephone staff of this fix.
Gsh22kgrecc freezer compartment howls
Check to see if fan is loose also check to see if there is ice buildup inside and blade is hitting it
2helpful
2answers
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
2answers
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
2helpful
Howling noise in the evaporator fan motor
Bad computer board in back of fridge, unable to control motor speed causing motor to hunt
4answers
Noisey ge side by side
hi thanks for the question that noise is the fan in the freezer.you replace the fan motor the water disp problem is the little switch inside the freezer door difficult to get at please accept with a positive feed back thanks the appliance doc
3helpful
2answers
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
4helpful
2answers
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
3answers
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
4helpful
2answers
Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
2answers
Howling - Which is the correct fix
I think I have the same problem. The unit is also about 2 years old (GSH25KGRBB). I have an extended warranty. They already replaced the controller card. I see it is the exact part number you have mentioned. It seemed to help for awhile but I think it has gotten worse again. The noise is more consistent after they changed the board. Less revving up to "turbo" mode. Howling is a good description. I can hear it now, on the other side of the house. I would change the fan out. I think they did the board first because it probably is easier even if the part cost is higher. I will probably call them back again. This will be the third time. The first time they just changed the little flapper on the ice dispenser. Otherwise the unit cools and runs flawlessly.
Top Refrigerators Experts
vince
Johnny 1000
