When embroidering script in the Plus Hoop, the P1 position stitches out beautifully. When starting the P3 position, a few letters stitch out in the upper right of the hoop, then upon repositioning, the needle drags across the fabric, snagging or breaking. The continuity of the design is lost, of course, and must be started over.
I've tried several solutions, to no avail. This is a reoccurring problem.
The machine stitches out the ordinary 4x4 designs perfectly well.
Here is what I am using:
Husqvarna Rose 605 Plus Hoop Schmetz embroidery needles Imperial Batiste fabric Wash Away stabilizer Spray Starch 40 Wt. Rayon thread 2 ply embroidery bobbin thread
I would really appreciate a solution from an experienced tech in this area. Thanks so much.
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
After I stitch out the p1, I have to go back and load the p2 design and continue stitching after I adjust the hoop to the p2 setting. Then I do the same thing with the p3. It is a pain to go back and forth, but it works!
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design. You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication. Note: You must select the Font, Size and Menu before selecting the letter desired. Do rate the solution accordingly.
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
It sounds like you have an alignment problem. You can try to move the needle over with the stitch button and run you machine by hand for the first go. If it jumps back over - you are going to have to take it in to be looked at. Good Luck!
Hi Ann, m-memories are not stitched with the hoop or embroidery unit. They are stitched with the #2 sewing foot and with the feed dogs up just like any of the 9mm decorative stitches on the machine. Linnette
