Hello everyone
Have you got any problems during printing pdf files on your biz hub 250?.
Computer sending files to the printer but very slowly. Printer doesn't print
informing about printing problem. It happens when i am trying print files larger than 1MB. Does anyone have similar problem?
I switched off printer and deleted print job on computer and printer
Restarted computer. Still doesn't work.
Other documents like doc, xls files are printed correctly,
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Uncheck "Collate" on the Print Dialog, print jobs now process 10 times as fast...
If printing thru a Windows Server/PC Host, have the Administrator go into the Printer Properties, under the 'Advanced' Tab, click on the 'Printing Defaults' button, uncheck "Collate", then click OK.
