I have a 1986 camaro, new high amp (70 i think) alternator. i have a 500k microfarad capacitor, 2 12" 150 watt rms rockford fosgate p1 punch speakers, and a 300 watt alpine amp. 6 gauge power wire, and 8 gauge ground wire with additional ground wire. a pretty new battery (750 cranking amps, 650 cold cranking amps)
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
i need to know how can i resolve my lights flickering. when i try to enjoy my music people think im a cop tryin to pull them over. not cool. couldnt i get arrested for inpersonating a police officer in the worse case scenario? lol.
well i cant find the right link to do the clarification thing, but its 300 watt max on my amp. 150 watt rms. thats what makes me wonder.
its 150 watt rms, 300 watt max. found the link to clarify finally. lol
when the car is idle is doesnt look any different than when im drivin or reving it up. the wire to the alternator thing sounds about right. and the ground wire thing. how big should the ground wire be, that runs from the battery?
is that 300 watts rms on your amp?
