SOURCE: washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
SOURCE: Dishwasher draining into kitchen sink!
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up. __________________
SOURCE: kitchen sink drain loose
You can probably tighten it from the bottom. But first, get a little plumber putty from the hardware store and put it around the seal from the topside of the sink. As you tighten it down, it will squeeze out a bit, but that is okay. Good luck!
SOURCE: kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
SOURCE: water discharges out of the
Sorry to read about your problem, I hope this helps you out.
you have 2 different issues. Blocked waste pipe and a defective water fill switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
