Washing Machines Logo
Markee Monrial Posted on Jun 25, 2019
Amana #lw615wm washing machine when I start machine for hot water it comes out slow when I put in for cold water it. Comes out fast?? Thanks
Eric Gundersen
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 25, 2019
Eric Gundersen
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
0
Helped
11120
Points
51
Clogged screen on water valve. Turn off both water faucets.Remove hose from valve. Pop out mesh or plastic screen. May be debris. Could be low pressure too if this doesn't help.
3 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 27, 2007
SOURCE: washing machine water control
remove the cold water hose from the back of the washer. look inside the area where you unscrewed the hose from. there is a screen in there. if its clogged with sediment remove screen and clean. if that doesnt fix it or if theres no sediment youll have to replace the valve to fix the problem
Anonymous
  • 26 Answers
  • Posted on Nov 26, 2008
SOURCE: My Admiral Washing machine only runs the hot water (not cold)
the water temp switch is bad call aplience parts store in the area
mgprice
Mike Price
  • 744 Answers
  • Posted on Jun 23, 2009
SOURCE: Cold water wash very slow fill up
Hi, you have a blockage on the cold side of your inlet valve, take the hose off on cold side of the valve and inspect screen..You may find some debris. If no debris is found you may have a bad valve..your going to need to replace it...if you have any questions please don't hesitate to contact
Model NFW7200TW Washer wont fill with water
Are you sure you have both hot and cold water connected? Try turning the water valve on, if you don't have hot water make sure you choose cold cycle. That's the first place I'd start.
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
Water comes out during fill and rinse cycles very slowly
Check your water pressure, make sure your supply is turned on fully. Is the water slow only on hot or cold? If so you may need to replace the inlet valve to the machine.
1helpful
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Cold water intake rusted
Hello there
The only real fix to this is to replace the water inlet valve on the machine it costs around 25 dollars or less to replace
2answers
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
1helpful
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
1helpful
Washing machine water control
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
