After washer started filling up with water there was a burning smell coming from it and it stopped. Any idieas of what the problem might be?
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
hi my f&p smartdrive 700 went trough the wash cycle fine but on final spin stopped and smoke was coming from bottom of machine , everything lights etc still work but when put on spin it starts smoking. hope you can help. Mike
