SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
SOURCE: Service Menu RCA HD56W58 56" TV
http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
SOURCE: Zenith H2533Y TV Entering Service Mode
I want to adjust colors setting of tv using lc863348a and 24c32.but I dont know the servicing code to enter ,please help.
SOURCE: sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
SOURCE: AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
