20 Most Recent Sharp AQUOS LC-32D44U 32 in. LCD TV Questions & Answers
2answers
Dont have the secret code, Ive tried 0000 and 1234 and doesnt worked.
Have you forgotten the secret code you set or do you want to create a new one?
12/16/2022 5:01:06 AM • Sharp AQUOS... • Answered on Dec 16, 2022
0answers
Apparent problem with TV backlight.
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
4/2/2017 3:47:05 AM • Sharp AQUOS... • Answered on Apr 02, 2017
My Sharp Aquos LC-32D44U Is malfunctioning.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/13/2017 10:26:55 AM • Sharp AQUOS... • Answered on Jan 13, 2017
We have a sharp 32in tv and it will not turn on when i plug it in the power light blinks red 2 times and green 2 times. i have tried many different things to reset the tv and nothing work
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/8/2016 2:08:14 AM • Sharp AQUOS... • Answered on May 08, 2016
My sharp Aquos LC-32D44U has a solid green power light but wont turn on?
1/13/2016 11:41:10 AM • Sharp AQUOS... • Answered on Jan 13, 2016
How to fix a tv that does not power on ?
1/13/2016 10:12:15 AM • Sharp AQUOS... • Answered on Jan 13, 2016
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
12/24/2015 8:27:06 AM • Sharp AQUOS... • Answered on Dec 24, 2015
Replaced power supply and reset still on light no sound just a flashing green light
12/24/2015 8:26:48 AM • Sharp AQUOS... • Answered on Dec 24, 2015
Sharp aquos no power
Hi, probably the power supply is faulty. Just watch the bellow added video to understand how to check the power supply a flat panel tv . Testing LCD TV Power Supply BoardsSTEP BY STEP http://electro-medical.blogspot.com/
11/3/2015 2:48:29 PM • Sharp AQUOS... • Answered on Nov 03, 2015
How to make picture on full screen
Hi, You have to go the menu of the tv and have to change aspect ration setting to 16:9. Here i have added the link the the manual of the tv which will help you to know how you access the settings. www.electro-medical.blogspot.com Sharp Aquos LC 32D44U Operation Manual
9/11/2015 4:21:28 PM • Sharp AQUOS... • Answered on Sep 11, 2015
Blinking power and opc light together then power by itself continuously
9/10/2015 9:00:56 AM • Sharp AQUOS... • Answered on Sep 10, 2015
Missing resistor on main power board resistor no r7637
Can you tell me where is the area to locate R7637? I have a power supply but can't find that part. The service manual doesn't have a part list to find that resistor.
9/6/2015 3:25:34 PM • Sharp AQUOS... • Answered on Sep 06, 2015
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
232 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
dont secret code ive tried 0000 1234
  • Televison & Video
