Hi, what the error code is telling you, NG: LCRSLSRBLBR, is that due to some output problem or power supply, the speaker outputs are not working, NG by Non Good, L by Left, C by Center, R by Right, SL by Surround Left, SR by Surround Right, BL by Back Left and BR by Back Right
I suggest you check all speaker connections, disconnect all speakers and see that this is the same, the problem is in the computer, if it does not indicate failure, then go connecting the speakers one by one until the fault appears again and in that last speaker connected, the fault could be, try all the speakers
I hope you can solve the problem, but look for a specialized technical service
Greetings Franco Dosil
Hola, lo que te esta indicando el c?digo de error, NG:LCRSLSRBLBR , es que por algun problema de salida o fuente de alimentaci?n, no est?n funcionando las salidas de parlante, NG por Non Good, L por Left, C por Center, R por Right, SL por Surround Left, SR por Surround Right, BL por Back Left y BR por Back Right
Te sugiero revises todas las conexiones de parlantes, desconecta todos los parlantes y observas que esta igual, el problema esta en el equipo, si no indica falla, entonces ve conectando de a uno los parlantes hasta que te aparezca nuevamente la falla y en ese ultimo parlante conectado, podr?a estar la falla, prueba todos los parlantes
Espero puedas resolver el problema, sino busca un servicio t?cnico especializado
Saludos Franco Dosil
SOURCE: e74 error code
i have found that the same fix for the ring of death also works on this error check utube for details on fix i have preformed this fix on 3 other customers machines with only 1 call back
SOURCE: Remote code for Pioneer VSX-50 A/V receiver.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: I have a Pioneer VSX-D411 and there is dsp ng
http://www.retrevo.com/support/Pioneer-VSX-D411-Receivers-manual/id/385ci976/t/2/
I believe it's trying to tell you something is wrong with its digital sound processing.
This was the best source I could find on it:
http://www.avforums.com/forums/av-amplifiers-receivers/381823-problem-pio-vsx811s-no-sound-display-says-dsp-ng.html
If you switch it to satereo / direct and the light goes out I'd say that would clinch it.
