I read a response on a different website where the guy having a similar problem took the car to his mechanic and they changed the antenna.
Another fellow said he solved this similar problem by doing a system reset. After the reset, he downloaded all of the system updates and reset the presets, etc. About 4 hours total but it did fix the problem.
SOURCE: sirius satellite radio
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
SOURCE: Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
SOURCE: Satellite radio (REF) not connecting with Sirius.
how do i use factory satalite antenna on a dodge ram 1500 2006 for after market radio
