20 Most Recent Sirius STILETTO 100 MP3 Player Questions & Answers
You can get service on this issue at ebay item# 360454064919
http://www.ebay.com/itm/
360454064919
Sirius STILETTO... | Answered on Jul 08, 2012
You can get service on this issue at ebay item# 400294280894
http://www.ebay.com/itm/400294280894
Mine lost the left channel then the next day lost all the channels. I cAN'T FIND A FIX EITHER
I am having the same issue, tried all solutions listed, it appears to be a hardware issue. Going to check with Sirius, which I doubt if they have any solutions for anything.
Found it on ebay, Item number: 360464140454
Sirius STILETTO... | Answered on Jun 05, 2012
some time it happens to some mp3 players.......... once it happened to my Ipod............at first I thought that it can't be solved.... but when I rebooted the system it began to sound through the both of two speaker..........
Sirius STILETTO... | Answered on Nov 29, 2010
I'm a relatively new subscriber, only having my stiletto2 for 3 months. It just started "not recording" and "deleting my recordings". In researching, I came to this thread. Since no one really seems to have posted a real solution here, I'll share what I've found elsewhere.
1.) Check to make sure your SL2 has the latest software (ZAP). To find out what version you have, navigate to Settings >> Device >> Device Info. If your software is not up-to-date simply connect your radio to Internet Radio for about an hour and it will be downloaded. You will get a notice on your screen when the update is complete.
2.) Perform a Full Shutdown of your SL2 at least once a month by holding the power button down for 10 seconds. If you do a lot of recordings it's advised to perform a shutdown weekly or more for best results. This will flush the system, clean up and remove old and expired recordings/replays and reduce general screen lag. For some this simple step has eliminated missing recordings all together.
3.) Do not use your SL2 as an archive device and try to avoid using your internal memory over 50% for the time being. If you do a lot of recordings it's also advised to disable Radio Replays.
If 1-2-3 don't work, try 4
4) Set and Erase
4a. go into your Settings Menu>>Device>>Reset & Erase.
4b. As soon as you complete the process (Reset & Erase) and have rebooted, you will need to connect to Wi-Fi again to again download the baseband update. Let it run for at least 30 minutes to ensure that it is able to get the entire update. Then tune to Satellite Radio it SHOULD complete the baseband update.
4c. You should see the Updating SIRIUS message for about 7 minutes. If it's only up for a minute or two, then it may bet hat the update failed again. You can check the Service Info screen to be sure.
4d. If you then shutdown your SL2 (by holding down the power switch for 5 seconds) then turn it back on, it should complete the baseband update process.
Sirius STILETTO... | Answered on Oct 31, 2010
If the screen is not working, then you are out of luck - no one fixes these, including the manufacturer (hint: if it is still in warranty, call manufacturer and said it spontaneously cracked - don't admit to having broken it).
If you are having a software problem instead of a cracked screen, get the Device Recovery tool from:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
-Tha Mp3 Doctor
Sirius STILETTO... | Answered on Oct 28, 2010
here is a link to the manual that you requested.
Click here for manual.
if you need further assistance please let me know.
Sirius STILETTO... | Answered on Aug 26, 2010
Sirius STILETTO 100 MP3 Player Logo
Popular Tags
83 questions posted
Top Sirius Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Anthony Ward
Anthony Ward
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sirius Audio Players & Recorders
Most Popular Question
sl 100 keeps restarting computer
  • Audio Players & Recorders
