I have the wireless switch but no actual doorbell and I'm tired of missing package deliveries.
Thanks for sharing. We provide full support for all your Linksys devices, including guidance for your my arlo login .So if you are having issues with connecting to the Wifi or configure settings on the Linksys app, then contact us using our live chat services or our email.You can also call us using our customer support phone number.Call at +1-844-456-4180 Toll Free Phone Number
You could but doing so would ruin the the wireless part of the push button, probably to no good effect. The push button would actually push a tiny switch on a circuit board that is designed to carry a tiny current.
A lamp or signal bell will require a significant current and a bell is an inductive load so is likely to promote arcing at the switch contacts.
Far better to obtain the parts needed to install a reliable old fashioned door bell that will last for decades...
SOURCE: My Desa Specialty doorbell doesn't ring..I have
Batteries are located in the doorbell push button case in the back. Slide open a compartment to reveal the batteries.
SOURCE: I am in need of the push button with the m/n 21/23
This looks like the Heath Zenith SL 6163. If that is what it is, the wireless push button on the link below will work. It is the SL 6163
http://www.1800doorbell.com/db800-wireless-battery-chimes.htm#SL6193
SOURCE: Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
SOURCE: everytime somebody rings my neighbors
It appears that you and your neighbor's wireless door bell are on the same radio frequency. You or your neighbor will need to change their base station (were the sound come out of) unit. If you or your neighbor still have their Owner's Manual you can find out how to do it in the Trouble Shooting Section. If that's not available, remove the cover, if necessary and you will find a small panel board with a series of movable slid switches (they are very small) . Moving those to a different position will change the frequency. The inside of the back cover should have instructions on how to reprogram it. DESA International bankrupted over a year ago, but some manuals in a pdf format are still available on line. Try http://www.desatech.com/ as there may be an Owners Manual that's still available. Different divisions of DESA International were sold off to other companies during the bankruptcy, so you may be led to another site. Good luck.
