Toshiba Tecra R850-F42N supervisor password forgotten.
See if this YouTube video will work for you
https://youtu.be/siSoOXkNSgw
Call Toshiba yet, only the can do that, unless hackers can.
we are not HACKYA, sorry, we don't do that its ******* .
here is where to ask.
https://support.dynabook.com/support/modelHome?freeText=2998366
other than that googling all week might work.
or pulling out all batteries
or shorting out 10 different magic solder pads on the motherboard, is sure way to brick it as seen on UTUBE.
also there are some laptops have back door,
hit enter 3 times see key code generated that may scalper sites online can decode and reset you password, $20 to $100 scalped.
SOURCE: i need to remove my bios password
Try to locate the CMOS jumper on board. Set the jumper from pin 1-2 to 2-3 and return it back to 1-2.. This will restart your PC to default settings and erase the password.
Maybe this could help..
Mon =)
SOURCE: supervisor password
The Supervisor password Holimon was referring to is the laptop's Bios password, which can't be recovered with conventional methods. The only method known to retrieve this password is by soldering a rudimentary eeprom reader to the motherboard. Details are here:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Not an easy solution even for the experienced...
A Supervisor password protects the system information stored in the BIOS. The user must enter the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to change the system configuration. If the Supervisor password is forgotten there is no way to reset it to enter the BIOS configuration. Setting a Supervisor password automatically sets the master Hard drive password. The following is the icon that comes up in the upper left corner if a Supervisor password is set:
A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To regain access, the system will need to be serviced to have the system board and hard drive replaced. Proof of purchase is required, and this repair is not covered under the warranty.
Document id: MIGR-59377
Last modified: 2005-06-17
Copyright © 2009 IBM Corporation
Copyright © Lenovo 2009, all rights reserved
SOURCE: forgotten bios password on toshiba tecra a10. How
Hi
Just reset it, to do it just open the memory compartment and look for the bios battery number 2025 or 2016 and take it out the battery for 1 minute just to be sure it will reset. Just feel free to ask. Hope it may helps.
Regards,
kaybicks
