SOURCE: Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
SOURCE: roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
SOURCE: Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
SOURCE: maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken. It needs replacing.
