These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Hi Jaswinder,
The led blinks continuously or it pauses after some blinks. If it pauses, can you tell me the number of times it blinks between two pause. Please quote the model number also.
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or
Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set
is placed in Standby, then On, symptom will re occur. If AC is removed,
set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal
inside TV. This causes TV to shut down with error 'Standby led flashes 5
times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search
for relevant model to download correct update. If the unit is in
Workshop, please perform update as per Instructions.
Solution for Sony Bravia KDL 46EX723 blinking red light 8 times. Information below is from Sony online support, it worked for me: Please disconnect the Internet connection from the TV and your TV will work fine.
We
are suspecting a network outage issue on Sony device, we are currently
investigating this issue. I am really sorry for the inconvenience
caused.Unfortunately we don't have any ETA on this,I request you to try
at a later time.
