SOURCE: microwave oven will not work
Seems like I've answered this before, but the MR5493G is subject to a recall due to defective keypad (membrane switch) and can be seriously dangerous.
See: www.allworldauto.com/recalls/samsung_microwave_mr5493g_recalls_1420-10455-1.html
The MR1032BB is also under recall. See: www.motorbeat.com/model/samsung+microwave/mr1032bb/
If neither is covered under the recall, you should be able to order new keypads here: http://www.samsungparts.com/search/search.asp
If not, we'd be happy to help you. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
SOURCE: kenmore microwave model 665.61629100
20amp fuse above the control panel.. but behind the vent grill..
SOURCE: Set clock time on microwave oven
I have consulted the Owners Manual and there is no mention of the demo mode. I would suggest that you unplug the unit or disconnect power if it is hard wired in, and try to set the clock then.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
SOURCE: my microwave oven keeps tripping the circuit
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad.
If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
