SOURCE: Set CD Clock Radio for Daylight Savings Time
I downloaded the manual from the Timex website give in a prior post.Here is a link to the manual in PDF: http://www.mediafire.com/?cn1kusjfosx
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
SOURCE: timex clock radio T245S
Try this
http://www.timexaudio.com/pdf/T245_IB37357_46.pdf
Also if the screen is flashing "OFF" toggle the tab on the left
SOURCE: how do i change a
Try to find the model here for a download.
http://www.timexaudio.com/product_manuals.asp
SOURCE: timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
