20 Most Recent
Timex T065s Solar Powered- Radio Controlled Atomic Alarm Clock Questions & Answers
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
How to set radio station on timex radio clock model t311t
Hello Glenn, I sent you the link to download the user manual of your Timex and follow the steps to configure the radio stations
Keep in mind that if the radio station is far away, you may have trouble tuning it
I hope you can solve your concern
Greetings Franco Dosil
Hola Glenn, te envio el link para que descargues el manual de usuario de tu Timex y sigas los pasos para poder configurar las estaciones de radio
Ten en cuenta que si la estacion de radio se encuentra lejos, podriastener dificultad para sintonizarla
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://cdn.ihomeaudio.com/media/product/files/T311IB57574_35.pdf
