The breaker itself did not trip, the clock will still illuminate and turn on and off.
Go to your electrical panel and check the circuit breakers. If one is tripped it will be in a halfway position. switch off then on. If it keeps tripping you may have to call a repair man.
Testimonial: "The breaker itself did not trip, the clock will still illuminate and turn on and off when the knobs are turned."
SOURCE: Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
SOURCE: I spilled water on the cook top and one burner is
cut the power at the breaker, wait for it to dry completely then turn back on. clicking noise is probably electricity arching
SOURCE: cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
SOURCE: How do I know if I have fully turned off the cook top?
The orange light is on to tell you the suffuse is still hot. It should go off after 15 minutes.
