Ashief valentine Posted on Feb 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Av 4337 cleaned dust n power still goes on then overload protection. Plz help
Grubhead
Level 3:
  • Audio Player... Master 5,755 Answers
  • Posted on Feb 06, 2019
 Grubhead
Level 3:
Answers
5755
Questions
Helped
1662746
Points
11417
Check all your speaker cables, connections and the speakers themselves for faults and shorts.
If they are all good and it still doesn't work, suspect a shorted device in the power amp section.
1 Related Answer
Anonymous
  • 111 Answers
  • Posted on Nov 04, 2009
SOURCE: Mixer goes off on overload protection when under a
This means that it is overheating, if there isnt to much mixture in the machine then the problem is in the motor. Depending on age and value of the mixer I would purchace another one as they are cheaper to buy. If it is still under warranty I suggest taking it back to the supplier that you bought it from. I hope thi is helpful.
I have an Onkyo TX-SR506 that does nothing but blink a red light when plugged in. This happened after a power-surge from a lighting storm hit it. Is there any trick or magic key command to get it out of...
Page 90 of the manual describes the procedure for resetting it.
"If you can't resolve the issue yourself, try resetting the AV receiver before contacting your Onkyo dealer.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Note that resetting the AV receiver will delete your radio presets and custom settings."
But that may not help.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
I have a panasonic sa-he70 av control receiver, it is showing on its screen OVERLOAD, SWITHC OFF POWER, i did it twice and still apperas same message. Is my equipment damaged or I just need to reset it?
Page 16 of the manual has recommendations.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Integra DTM 3.5 AV receiver. The unit goes into protect mode when I try to turn it on and then shuts itself off. How do I fix it?
Do more triage first.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
3helpful
My sony mhc-s9d goes to 'push system protect;
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
When i hook my samsung hw c500 home theater av receiver up to anything and turn it on, it goes straight into protection mode and shuts off. how can i get the protection mode to stop popping up so that i...
First, disconenct it and see if it can come up stand-alone.
My aiwa AV-X200 shut off while playing and wouldn't come on again.
My Aiwa AV-D98 Receiver keeps powering off at random times.
1helpful
My sony av receiver with nothing connected goes into PROTECT mode. what shoul I try?
You don't say under what conditions it does that so...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Amp goes in protection mode
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on. Check for loose speaker connections.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Hi. i love my sansui. it worked yesterday but today it only comes on but no sound. the sound will kick in for a second at a very low volume but immediately will cut off. plz help thanks.
Generally speaking, an amp protects itself from heat, shorts and overloads.
 Grubhead
Grubhead
SmartAviator
SmartAviator
