If it is not available in the BB store(its not) then you need to search for the apk on the internet which you may not find, and if As long as they support android 4.3, it will run on your device with some glitches. that means you need to have 4.3 running on your device. it may be possible however may not be worth what you have to go thru to MAYBE be able to use a crummy version of it. Best of luck
Questions? Just ask
Mr.Mike
https://www.6ya.com/mr.mike
SOURCE: I had a blackberry curve 9320 bt I can't receive
I had one, nothing beat taking the battery out for a bit and reinstalling. hope it helps?
SOURCE: I have been downloading episodes from O2tvseries
This series of events may cause software to be unable to bind to a specific local endpoint and to be unable to listen."
SOURCE: Blackberry 9320 curve how cn I send and receive
As long as you have an active working SIM card and account, all you need to do is set up the email again. If you need help with that, go to
http://support.blackberry.com/ for the step by step on setting up an email account on this phone. You might also be able to set up the email using your carrier's system if they support it.
