ZTE MF985 I can't log into ATTwifi manager with out a connected device, so I can't change the password. The password was appearently asighned by the factory couase i was not asked to create one when I set up my account. network is active and reconized by my devices and I have service, as my signal bar indicates
SOURCE: I have a Toshiba E-Studio
This is just for the web site so it has the solution to the printer issue we fixed. Thank you
Testimonial: "Worked tirelessly with me to get this issue resolved and the printer working correctly! "
SOURCE: lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: when connecting the samsung lan adapter to my sams...
There should be a reset either hard,"button" or soft, Plug in the computer and run any software that came with it, Please let me know how you made out, I have been wanting to run my pc movies into my Sammi at the other side of the house, but most of the products I looked at have spotty service at best, There is a new one at Best Buy , that does live streaming in hdmi if you already have the adapter, for lie 60-70 dollars, I will await your response,
Gymowner
SOURCE: WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
SOURCE: Problem with setting up a wireless connection
Looks like, you are installing in vista or Windows 7..Sometimes in these OS , it needs elevated privilages..Try to enable in Network connection by clicking RIGHT CLICK on network icon & run as Administrator privilage..OR try to install with Administrator privilages...I hope this will work
OR if there is driver problem,,Try to download drivers from the below link
http://homesupport.cisco.com/en-us/wireless/valet/AM10
Please rate & vote if you like solutions
Thanks
Sandeep
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Unfortunately, there is no way to recover a lost or forgotten password
from a router or access point; you will need to reset the device to
factory defaults. However, once the device is reset to factory defaults,
you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
hope this helps
3. From the center screen, select your encryption type from under the Security Options heading.
hope this helps
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
