You can often use the ZTE Free IMEI unlock calculator to unlock the ZTE devices. Click link below to check and please 'Thank' if I helped you.
ZTE Unlock Code Calculator Win Tech Mobiles
Try forgetting the wifi and connect it again.
if doesn't work, try restarting your router. just make sure you wait about 30 seconds before starting your router again.
Regarding the issue of address pools, the OLT establishes an address pool. Each address pool is a Class C address and 255 IP addresses.
As for how many address pools can be established, log in to the device, press"?"+ "Enter" to see how many address pools can be created.
www.mywifiext.net a one stop solution shop for all your queries related to Netgear WiFi Extender Setup and Netgear Login issues. Get in touch will the leading technical experts, who are eager to provide you with the best assistance for Netgear WiFi Extender 24*7. Just dial to our toll-free number +1-888-961-4011 for Netgear extender Setup solutions.
Phones do not usually have a WPS button; they often have an option to use the WPS button during Wi-Fi setup. Your wireless router may have the WPS button; check the manual or look at the router for the button location. To connect the phone to a router with a WPS button, go to Settings (from All Apps) and choose Wi-Fi. Make sure that the slider is set to On. Then tap on the icon with three dots in a black rectangle. Choose the Advanced option. Tap the WPS Push Button option and then push the WPS button on the router.
I looked at the AT&T manual for the ZTE Z835 (Maven 3) for the specifics on this section of the Wi-Fi setup. See page 44 (page 46 of the PDF) of the manual: https://images.comparecellular.com/phones/2673/ZTE-Maven-3-user-guide-ATT-english.pdf .
I hope this helps.
Open a browser and access the web management page via http://192.168.0.1 the default password is "admin".
Go to Settings > Network settings > Dial-up Settings > make sure to enable the Roaming Status. Then go to APN > Change Mode to Manual and enter the below.
Profile name = WorldSIM APN = mobiledata Username = Leave it blank Password = Leave it blank and Click Apply.
also checkout my youtube channel I teach alot of windows and mobile phone stuffs therehttps://youtube.com/digitaldegs
Hello Lonnie, for the issue network please call your provider company ATT if is not activate the new phone you can not use until the line gets an update; about the wifi connection if you have any internet provider or access to wifi connection just go to the setting on the phone then get connect, maybe need put the username and password of the internet provider or it is open connection wifi as well.
Clear Cache and Data in Google Play Store App:
This should be done from the System Settings by ust following the steps given below. Make sure that before you go and do this step you have to Turn off Google play updates from the Play Store app. Open Paly Store and tap on the 3 dots option icon on the right or left side top of the screena nd from the list of options turn it off.
Go to System Settings on your android device which is Gear shaped icon -> Tap on Application Manager or Apps in the list of options -> Then Open "All" apps
From the List of Apps available in the All apps search for the Google Play Store App and Tap on it which will open a new window.
You should click on the Clear Cache button and Clear Data button as shown in the image below.
Now Restart or reboot your device and try to install or update the apps which will most probably solve the problem. If you are still facing the same error and problem follow the next step.
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
