SOURCE: Won't burn picture image
http://www.liteonit.com/global/index.php?option=com_content&task=blogsection&id=9&Itemid=69
if you can copy an image ( alone- nothing else waste a disc here) as a data file it's the software - uninstall and re-install it--- if you cannot copy the image as a data file , it's the software in a different capacity and may you need firmware from the link - I would uninstall the device in device manager and then let wizard find it on a re-start
SOURCE: Nero DVD burning Burning problem
Devil is in the details...
1. What O/S are you on?
2. What make and model of PC are you using?
3. What is the burner you are using (make and model)?
4. Most importantly, what kind of files are you burning? (ie, .avi, .mpg, .wmv, etc.). Codec information is very helpful here. Use GSpot to get the codec the vid was encoded it: http://www.headbands.com/gspot/
So it begins!
SOURCE: Nero Vision 4 refusing to burn to DVD (Memorex DVD Burner)
if its having problems writing the lead in, it,s possible that the devices drivers are corrupt or incorrectly installed. to resolve this re-install nero, or better still upgrade to a newer version of nero.
also check that your media/ blank dvds are compatable. some writers support DVD-R But not +R.
if none of the above works, go into the device manager, and uninstall the DVD drive, reboot the computer, and re-install it. Other related problems are usually atapi or couffin drivers.
Mike @ compurepair.
SOURCE: Nero cannot burn DVD inserted in my LG GSA-H55N DVD-RAM rewriter
I have the same problem, my drive doesnt want to write anything for that matter...possible faulty hardware?
To Amnonk: Are you f*$&ing stupid? Your answer is retarded
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
