SOURCE: mirro pressure cooker instruction manual
You can find one here.
http://www.pressurecooker-outlet.com/mirromanual.pdf
SOURCE: Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
SOURCE: User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
SOURCE: lost owners manual
Here's a link to this manual directly from QVC...
http://www.qvc.com/man/k/k37000_man.pdf
SOURCE: I need a operatin manual for a cook's essentials pressure cooker
I bought a cook's essentials pressure cooker but it has no instructions. it's a 7L. with onlyone turn knob with the #'s 1 & 2 then a steam picture. it also has a lock button that's it. Can anyone help?
You should Refer to online search to find user manual or download it from manfaturers website
