SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
SOURCE: The bobbin on my Husqvarna sewing machine (Viking
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
If anyone is still having this issue, try raising the foot. Many frustrated hours later this worked for me and I wanted to wring the neck of the person who forgot to put it in the instructions! Happy sewing!
Thank you!!!!!!!
THANK YOU!!!! I searched everywhere, and you are the only person who gave me the correct answer!!!!
