Garden Logo
m
michael Posted on Nov 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Struggling to push through the fuel line on a mac 738 chainsaw. This is the one with the attachment to stop it coming out. Any suggestions please? Posted on Nov 05, 2018
dannydoesita
Level 3:
  • Master 778 Answers
  • Posted on Nov 05, 2018
dannydoesita
Master
Level 3:
Answers
778
Questions
Helped
226882
Points
6375
Usually you insert the fuel line from the outside in. Pull the line out through the fuel tank hole far enough to install the part that keeps fuel line from coming out, and then pull the line back out the way you just came in. Remember the fuel line should be a little thicker then the hole in tank, also after you install your stopper you can also install the fuel filter and then pull and push everything back in. If you need more help I would be happy to help you further. Good Luck Friend
  • michael
    michael Nov 06, 2018
    Thanks Danny, I managed to push it through, to get the cap off, by inserting a piece of wire coat hanger down the pipe. Was easy then. Now trying to get the new pipe in. It's a but rubbery so may try to source something better.
5 Related Answers
Anonymous
  • 2220 Answers
  • Posted on Oct 25, 2009
SOURCE: I have a poulan 2150 chainsaw. I replaced the
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Anonymous
  • 2220 Answers
  • Posted on Feb 04, 2010
SOURCE: mccullough mac 4600 chainsaw gas line connections
This is an example of a typical fuel system with a few suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Your basic model number is 600465. I only saw 11- prefixes used with 600465s, no promises I did not miss any. There are a few different suffixes with the 600465s. I think the suffix is on your saw immediately after the basic model number somewhere (On older Macs it is usually on the bottom along with the serial number. The dash of the serial is often the correct prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.htm
I chose "11-600465-09" as an IPL example:
http://www.ordertree.com/modelinfo/MCC/11-600465-09-MAC-4600-10%2F94-to-Current-IPL-211594/139.11-600465-09-MAC-4600-10%2F94-to-Current-IPL-211594.1.59.1.html
I find these helpful when getting into an area of repair I am unfamiliar with. Also all components are displayed and part numbers listed.
If you find different size hose a small sample of each taken to a local saw outlet should provide something suitable. Please ask how long they feel any replacement should be (usually 12" ample). HTH
Lou
If you have additional questions you can reply below and I will assist you further.
Anonymous
  • 2220 Answers
SOURCE: need diagram for Mccullogh Mac 4600 Chainsaw
Duplicate post - please refer to the other post; there may clarifications appearing there that do not appear here.
McCulloch IPLs
Lou
Duplicate answer
Anonymous
  • Posted on May 27, 2010
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Anonymous
  • 4088 Answers
  • Posted on Jul 16, 2010
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
1helpful
Craftsman chainsaw fuel line and fuel filter
go to sears and purchase the fuel filter and fuel line kit for the chainsaw. in that kit will have a hook that you fish through the outside of the tank to the inside, you attach the new fuel line after attaching the fuel line to the fuel filter, to the hook, then pull it through the hole. disconnect the hook from the fuel line, cut the small piece off where the hook made the hole and attach to the carburetor. finish by pushing in the fuel filter inside the fuel tank. the kit will also have more detailed instructions and possibly with illustrations. if sears doesnt have the kit, check with a lawnmower repair shop.
Need to replace all gas lines
  1. Empty the fuel tank on the chainsaw of any remaining fuel. Pull the cap from the tank and turn the unit upside down. Drain the fuel into an approved fuel container. If the fuel is old (more than about a year) dispose of it according to local regulations for hazardous materials. (It can be kept longer by adding a fuel stabilizer.)
  2. Pull the fuel line where it attaches to the carburetor using the end of the needle-nose pliers. The old fuel line may take some force to pull free from the metal tube.
  3. Push on the fuel line to feed it into the fuel tank. Hold the chain saw upside down. Shake the unit to get the fuel filter into the opening of the tank. Pull the filter free of the tank. Feed the remaining fuel line through the access hole at the bottom of the tank. Dispose of the filter and old fuel line in accordance with disposal regulations.
  4. Feed one end of the new fuel line into and through the bottom access hole of the fuel tank. Push approximately 6 to 8 inches into the tank. You can pull back any excess line later. Grab the end of the plastic line with the needle-nose pliers. Bring the line through the gas tank fill opening.
  5. Attach the new filter to the end of the new fuel line. Feed the filter back into the fuel tank. Pull any excess line from the tank. You will want approximately 3 to 4 inches of fuel line inside the tank.
  6. Route the new fuel line to the carburetor. Cut the line to length with the cutters on the needle-nose pliers. Attach the line to the metal tube.
  7. Fill the fuel tank with fresh gas-oil fuel for 2-stroke engines and start the chainsaw. It may take a few pulls to prime the new line with fuel.
  8. Some models come with a priming bulb. Make sure you press the priming bulb three to four times before trying to start. This will prime the gas lines and remove any excess air trapped in the lines.
Trying to replace a fuel line on a mcculloch trim mac 210 ,need to know what is attatched to the lines inside the tank, fuel pickup etc
Struggling to push through the fuel line on a mac 738. This is the one with the attachment to stop it coming out. Any suggestions please?
May 21, 2010 • Garden
What are the steps to re-attach throttle to trigger and fuel line to tank on Mac 110? If the fuel line is attached first, the trigger seems impossible to reach and if the trigger is attached first, can't...
Did you remove the rear case first? That allows direct access to the fuel tank and line. I have found the throttle trigger connection to be the worst offender when the front case is removed to access the carburetor and ignition system. Hope this helps!
May 05, 2010 • Garden
2answers
It runs or a few secs and then cutts out and will not start again the its a mac 738 about 2 months old
check the carb. it may be clogged. also check your fuel lines they be dry rotted and allowing fuel not to get to the carb.
Mar 01, 2010 • Garden
2answers
McCulloch Chainsaw carb not getting fuel
This is the same problem I have with a Mac 3200. I have: (1) A line from the primer bulb to the front port on the carburator. (2) line from fuel tank, with attached fuel filter, to the other primer bulb port. (3) Line from port on back of carb. to ????. I thought it must be a pulse line, but not certain, and don't know where to run it to. Please let me know when you find out.
73helpful
3answers
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Top Garden Experts
Jay Finke
Jay Finke
john h
