SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
SOURCE: whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
SOURCE: whirlpool self cleaning oven 465 capacity model oven doesn't get
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
