SOURCE: batteries are dead can't open safe
I had the same problem. We finally located where the batteries were hidden. They were below the keypad, There is a silver, plastic cover that slides to the right to expose the 4 AA batteries. Hope this helps you.
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button. The safe opened. The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe. Wrong! Do it my way should this problem happen to you.
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
SOURCE: Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
SOURCE: Dead battery! CANNOT OPEN SAFE
This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
