It might be one of the following:
1. Voltage changeover selector switch has blown - check if the power is still there before it enters the switch and still there after it leaves.
2. Breaker has failed on that leg - test before and after to see if working correctly
3. The plug socket has failed - Look for burn marks where wiring enters.
3. There is a fault in the alternator - see 2nd video down on this page for testing:https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Hope this helps you. If you need more advise please contact us on our website www.generatorguru.com. We are always happy to help.
Kind regards
The Generator Guru Team
www.GeneratorGuru.com
Generator Guru
SOURCE: Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
SOURCE: DBX DriveRack PA power failure
repair the transformers,,,using a digital voltmeter when both transfrormer are good the measure like 56 ohms, if one is good and the other is bad is gonna measure like 120 ohms , if both are damage it will measure nothing, all this with the switch in its on stage.
If you dont find anyone that can repair the transformers buy them.
SOURCE: 120v Bose Wave Radio/CD player plugged into 240V outlet
There is a fuse you can check. Also a rectifier bridge, a 3 terminal regulator IC (18V in, and 10V out) as well as a small transistor Q1 which often shorts. Easy and cheap fixes, or I would offer to buy your non-working model Bose if you decide to sell it.
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
