This sounds more like a driver issue than a software problem. The ArtLink 6 software CD that came with the Aurora 430 had drivers for XP and Windows Vista. However, these drivers may have only been for the 32-bit OS. Windows 7 is the first version of the OS to have had a large number of 64-bit installations.
The latest drivers for the Aurora 430 is available here: https://berninaofamerica.zendesk.com/hc/en-us/articles/200183069-Aurora-Driver-Windows-Vista-7-and-8- . You will need to install two drivers; follow the directions on the site. Make sure that the USB cable is good and that you aren't using a USB hub.
If you have installed the drivers and the ArtLink 6 software still isn't working, ArtLink 7 is fully compatible with Windows 7 and the Aurora sewing machines. The only download site for this software that I've found is https://www.bernina.com/en-CA/Products-CA/BERNINA-products/Software-Designs/BERNINA-Embroidery-software/Advanced-Embroidery-Software/ArtLink-Seven . ArtLink 8 is also Windows 7 compatible. However, I haven't found any documentation on the supported sewing machines.
The driver issue also applies to the dongle. Try this site: https://www.bernina.com/he-IL/Support-IL/Software-he/Embroidery-Software/Dongle-Driver . However, since you have the Editor Lite v4, this dongle may not be supported under Windows 7. The dongle driver is not updated regularly. For some information about the software limitations, see https://www.bernina.com/he-IL/Support-IL/FAQ-he/Software-he/Can-I-update-my-BERNINA-embroidery-software-Editor .
I hope this helps.
(There is a patch for the v5 software to run properly under Windows 7. There isn't one for the Editor Lite v4 to the best of my knowledge.)
SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
SOURCE: Bernina Aurora 430
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
SOURCE: husqvana designer1 embroidery machine
If you are using the 3D version of the Husqvarna Viking software, you may need to download the latest dongle drivers.
If it is 4D, you may need to update the dongle and you can do it yourself.
Check for support at:
http://www.husqvarnaviking.com/us/8588.htm or go to your local Husqvarna Viking dealer.
If you are trying to run 3D on a Vista computer it can be a little complicated. Let me know if this is the case.
SOURCE: Seeking ARTlink V2.0 - Service Pack Driver Update 2.19
Another possible approach. Again, researching for my own problems, I wrote to Bernina. They gave me the link to the old database, which, well, maybe it's just me, but I couldn't find this from their current site. I saw some info about an Artlink download that is available, but not supported, so maybe it's the one you want. Hope so. .
http://berninasupport.custhelp.com
SOURCE: The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Warning - undertake this fix at your own risk as it will probably invalidate the warranty.
The problem is a bad connection inside the embroidery unit - there is a small plug that joins four sets of wires that comes loose.
1) disconnect the embroidery unit
2) Turn the unit over and remove the posidrive (crosshead) recessed screws on the bottom. ONLY remove the recessed screws NOT the ones holding the catch to hold embroidery unit to machine. ALSO DO NOT remove the one screw that is different (it has different head that allows a flat screwdriver as well as a posidrive)
3) Carefull turn unit back over
4) With the enbroidery unit facing you there is a screw facing you in the white cover of the hoop holder. Remove this screw and carefully remove the plastic cover.
5) On the underside of the hoop holder nearest you there are two black screws that are undone with an allen key. Remove these (they allow the main cover to come off
6) Pop out the long plastc cover under the hoop holder (where the ting moves back and forward)
7) Pop out the section of cover behind this that is now loose.
8) Carefully tease off the main cover. IT will come with patience and by moving the embroidery arm back and fortht to give space. DONT FORCE IT.
9) You will see the rails running left to right that the hoop holder moves on. Under these you should see four wires, that are joined to four other wires by a connector.
10) Wobble the connector to get them to connect again
11) Connect the embroidery unit to the machine and switch on.
12) If the carriage goes to the start position you have restored the connection. Secure with insulation tape
13) If not switch off, wobble, switch on unitl it works
14) Disconnect and replace covers.
Good luck. This sorted out our machine that just moved the carriage the wrong way and flashed red 88
