SOURCE: Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
Testimonial: "Thanks - i'm gonna hv to take in in for the experts as i couldnt see anything visually."
SOURCE: NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
SOURCE: sur mon ampli onkyo tx-nr656 j'ai un message d'erreur NG:BL
http://forums.onkyousa.com/viewtopic.php?p=34909&sid=098aa0e82317330d8149a5fad397bcc7
https://translate.google.com English to French translation
https://translate.google.com/translate?sl=auto&tl=fr&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fforums.onkyousa.com%2Fviewtopic.php%3Fp%3D34909%26sid%3D098aa0e82317330d8149a5fad397bcc7&edit-text=
